How could I add from Design Library an Elbow to a flange using Routing but to control the angular orientation relate the flange
Question asked by Sorin Albu on Jan 3, 2019
Please how could I add from Design Library an Elbow to a flange using Routing in Edit Route Session, but to control the angular orientation relate the flange central axis without to start a pipe from the flange, practically the elbow will be add direct to the flange. There is possible different options solutions  in routing, and in the same time is possible to have an Instrument that could control the angular orientation... Thank you so much I really appreciate a fast accurate answer, step by step, some pictures or pdf could help a lot, the flange could be weld neck flange 150 NPS3, and the elbow 90deg lr inch 3. I work with SW2016 SP02;
THANK YOU.
Best,
Sorin,
