Property manager page control captions refuse to display
Question asked by Alex Baer on Jan 2, 2019
Latest reply on Feb 17, 2020 by Brian Foley
Hi All,
I've created an Add-In with VB.net and everything seems to work ok aside from that captions refuse to show-up on my property manager page. I can't figure out why. I've tried declaring the caption as a string and I've also tried putting the string in directly when creating the control. I've also tried removing some of the controls in case they are causing an error but still not luck.
I've written Add-Ins before and not had this problem so the inconsistency is frustrating. I've looked around the forums here and couldn't find a solution.
For reference, I'm on SolidWorks 2017 SP5.0
Please let me know if you have any suggestions.
Thanks!
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
Imports SolidWorks.Interop.swpublished
Public Class UserPMPage
    Dim iSwApp As SldWorks
    Dim userAddin As SwAddin
    Dim handler As PMPageHandler
    Dim ppage As PropertyManagerPage2
#Region "Property Manager Page Controls"
    'Groups
    Dim group1 As PropertyManagerPageGroup
    'Controls
    Dim selectionbox1 As PropertyManagerPageSelectionbox
    Dim selectionbox2 As PropertyManagerPageSelectionbox
    Dim numberbox1 As PropertyManagerPageNumberbox
    Dim numberbox2 As PropertyManagerPageNumberbox
    'Control IDs
    Dim group1ID As Integer = 0
    Dim selectionbox1ID As Integer = 1
    Dim selectionbox2ID As Integer = 2
    Dim numberbox1ID As Integer = 3
    Dim numberbox2ID As Integer = 4
#End Region
    Sub Init(ByVal sw As SldWorks, ByVal addin As SwAddin)
        iSwApp = sw
        userAddin = addin
        CreatePage()
        AddControls()
    Sub Show()
        ppage.Show()
    Sub CreatePage()
        handler = New PMPageHandler()
        handler.Init(iSwApp, userAddin)
        Dim options As Integer
        Dim errors As Integer
        options = swPropertyManagerPageOptions_e.swPropertyManagerOptions_OkayButton + swPropertyManagerPageOptions_e.swPropertyManagerOptions_CancelButton
        ppage = iSwApp.CreatePropertyManagerPage("Create a line pattern", options, handler, errors)
    Sub AddControls()
        Dim leftAlign As Integer
        Dim controlType As Integer
        'Add Groups
        options = swAddGroupBoxOptions_e.swGroupBoxOptions_Expanded + swAddGroupBoxOptions_e.swGroupBoxOptions_Visible
        group1 = ppage.AddGroupBox(group1ID, "Geometry for faster pattern creation", options)
        'Add Controls to Group1
        'Selectbox 1 - This will be where we select the sketch
        controlType = swPropertyManagerPageControlType_e.swControlType_Selectionbox
        leftAlign = swPropertyManagerPageControlLeftAlign_e.swControlAlign_LeftEdge
        options = swAddControlOptions_e.swControlOptions_Enabled + swAddControlOptions_e.swControlOptions_Visible
        selectionbox1 = group1.AddControl(selectionbox1ID, controlType, "Center line", leftAlign, options, "Sketch to serve as center line")
        selectionbox1.SingleEntityOnly = True
        ''Attempt to only allow a sketch to be selected
        Dim filters1(0) As swSelectType_e
        filters1(0) = swSelectType_e.swSelSKETCHES
        Dim filterObj1 As Object
        filterObj1 = filters1
        selectionbox1.SetSelectionFilters(filterObj1)
        ''Selectbox 2- This will be where we select the normal surface
        selectionbox2 = group1.AddControl(selectionbox2ID, controlType, "Normal Surface", leftAlign, options, "Surface that will have lines normal")
        selectionbox2.SingleEntityOnly = True
        ''Attempt to only allow a surface to be selected
        Dim filters2(0) As swSelectType_e
        filters2(0) = swSelectType_e.swSelSURFACEBODIES
        Dim filterObj2 As Object
        filterObj2 = filters2
        selectionbox2.SetSelectionFilters(filterObj2)
        'Numberbox 1 - This will be how many fasteners we want along the curve
        controlType = swPropertyManagerPageControlType_e.swControlType_Numberbox
        numberbox1 = group1.AddControl(numberbox1ID, controlType, "Count", leftAlign, options, "How many fastener lines should be created along the curve")
        numberbox1.Height = 40
        'Numberbox 2 - This will be the length of the fastener lines that we'd like
        numberbox2 = group1.AddControl(numberbox2ID, controlType, "Length", leftAlign, options, "How long should the normal lines be")
        numberbox2.Heigh = 40
End Class
