Hi i design mold by solid works and use to surface but dont show in surface bady ... why dont show all surface?
Just out of curiosity, is the knit the last feature or near the end? Have you tried doing a simple ctrl+Q to see if the folder updates?
Steve C
I would start by looking at the original part import and fully analyse. Start with import diagnostics and check tools.
Going back in the history and tracing what exactly caused the error may give you a direction of what is causing it.
Also it's better to have the parts imported separately and have them as stand alone part files you fix and adjust and are able to send to the client if modified. Then insert them into your cavity split line. (Personally I would even go a step further than that and have a impression layout with scale added).
But basically I would bet it is some of the surfaces in the original part files that need remodelling/trimming/deleting. The VAR spend the same time searching and fixing them as you would.
Could you attach your file?
