Leonis Wong
Create multi-line custom property with macro
Discussion created by Leonis Wong on Dec 28, 2018
Latest reply on Dec 29, 2018 by Deepak Gupta
Just to share this simple macro codes for those users who need to create multi-line description in custom property tab.
What it does is that it will create 4 empty lines in your description tab,
Then you can proceed to enter your description and click apply.
I have modified the code to also include original description value if there's any so as not to overwrite it accidentally.
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
'Get Full Path to active file
Dim Filename As String
   Filename = swModel.GetPathName
   Debug.Print Filename
'Get active configuration name
Dim configName As String
   configName = swApp.GetActiveConfigurationName(Filename)
   Debug.Print configName
'Point to customer property object
Set swCustProp = swModelDocExt.CustomPropertyManager(configName)
'Create multi-line format description
Dim newDesc As String
  newDesc = swCustProp.Get("Description") & vbLf & _
                     "" & vbLf & _
                     "" & vbLf & _
'Copy custom property to Description
swCustProp.Add3 "Description", 30, newDesc, 1
'Rebuild
Dim bRetValue As Boolean
  bRetValue = swModel.ForceRebuild3(True)
