Assuming a cube of 50 x 50 x 50, I want to chamfer all the vertices to 10 mm with all the chamfer dimensions equal. If I want to perform this operation, it allows me to select a single vertex.
As you can see in the attached video, what I try to do is to chamfer only the vertices simultaneously in a single operation without touching the edges of the piece but only let me select a single vertex per operation. If I try to select several vertices, the operation changes the first vertex selected by the next one selected.
This cannot be done yet as that feature can only chamfer 1 vertex at a time. There is an enhancement request for this currently (SPR-910700). What you can do however is things like mirroring the chamfer and then mirroring the original plus the mirror and repeat for 3 mirror and then you will have all corners mirrored and this allows you to have 1 master chamfer that you can change to change them all.
