Having issue retrieving component name using Name2
Question asked by Ninad Kulkarni on Dec 26, 2018
Latest reply on Dec 27, 2018 by Ninad Kulkarni
I am trying to make a macro for adding components & applying mates. For adding mates I need to access the name of the component that I have added. Below is my test code for the said part. Once I get the name I can set up the mates using another user-defined function ( I have this already).
I am getting a runtime error '91': Object Variable or With Block variable not set.
I can't figure out I am going wrong being a green coder. Can anyone help?
(The file paths & component names are changed)
Option Explicit
Dim swApp As New SldWorks.SldWorks
Dim swModel As ModelDoc2
Dim Part As SldWorks.ModelDoc2
Dim swAssy As AssemblyDoc
Dim AssemblyTitle As String
Dim sCompName As String
Dim errors As Long
Dim warnings As Long
Sub Main()
    Set swModel = swApp.ActiveDoc
    AssemblyTitle = swModel.GetTitle    ' Get title of assembly document
    Dim part_List(7) As String
    part_List(1) = "0001"
    part_List(2) = "0002"
    part_List(3) = "0003"
    part_List(4) = "0004"
    part_List(5) = "0005"
    part_List(6) = "0006"
    part_List(7) = "0007"
    Dim i As Integer
    For i = LBound(part_List) To UBound(part_List)
    sCompName = "File_path" + part_List(i) + ".SLDPRT"
    Set Part = swApp.OpenDoc6(sCompName, swDocPART, 0, "", errors, warnings)     'Open that specified part
    Set swModel = swApp.ActivateDoc3(AssemblyTitle, True, swUserDecision, errors)     ' Activate the assembly so that you can add the component to it
    Set swAssy = swModel
    Set swComp = swAssy.AddComponent5(sCompName, swAddComponentConfigOptions_e.swAddComponentConfigOptions_CurrentSelectedConfig, "", False, "", -1, -1, -1)
    Debug.Print (swComp.Name2())
    swModel.ClearSelection2 (True)
    swModel.ViewZoomtofit2
    Next i
Here is the sample code I am using
2019 SOLIDWORKS API Help - Add and Mate Component Example (VBA)
