How do you make a one way cut? I would like to plunge the bit into one end of a cut, make a straight cut, then lift the bit up at the other end. In every operation I attempt, the cut wants to start in the middle or start at one end and come back to the starting point.
I thought this would be a simple problem to solve, but unfortunately no one has solved it. I guess it is more difficult than it seems. I assumed I had missed a simple solution, but the only way I can see to solve it at the moment is to remove part of the code so that it will not return to the starting point. If anyone at all knows another, simpler solution, please let me know.
