MOMark Otteson21/12/2018
I have a sheet metal part that is going between two sheet metal sides that are angled. With a standard extruded cut, you get an angled edge on your flat layout which won't work for laser cutting. Chose Normal cut and optimize geometry to get the square edge on the formed part. SolidWorks 2018SP05 can't unfold the part because of a beveled edge. I need the sharp edge for the DXF for laser cut. part is attached Any ideas?
