I'm currently getting a rebuild error for an extruded cut option on sheet metal for the sketch contour on the bottom portion. The weird thing is that the successful top cut is made from a mirror entity of the bottom sketch. They are both on the same sketch and I've tried cutting only the original (bottom part) sketch but receive this error. Any help on the problem would be great!
looks like a glitch with sheet metal cut extrudes.
Close off the contours and it will extrude cut.
