macro to save sheetmetal from assembly to dxf
Question asked by Oliver Klöne on Dec 23, 2018
Hello there.
I hope you can help me out, as i'm done with my "magic"
Can you help me, to
a) manually choose a destination folder when starting the macro (e.g. starting macro -> where do you want to save pops up -> browse for the destination - > macro creates Material and Thickness folder in the set destination folder and saves all parts of assemblys and sub-assemblys there)
b) I need to export the layers from my line map - it only exports the geometry, no sketches for example. How to solve this problem?
Tested the line map by exporting the part to .dxf manually and it worked well.
#TASK does the job, BUT it exports every part, and i have some configurations where i set some parts to not be in the bom etc... so thats actually a deal-breaker for me.
***attached is the code
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim nStart As Single
Dim bRet As Boolean
Set swModel = swApp.ActiveDoc
Set swConf = swModel.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
Debug.Print "File = " & swModel.GetPathName
TraverseComponent swRootComp, 1
Debug.Print "Finished!"
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp                                          As Variant
Dim swpart                                              As SldWorks.PartDoc
Dim swChildComp                                         As SldWorks.Component2
Dim swConfig                                            As SldWorks.Configuration
Dim swConfMgr                                           As SldWorks.ConfigurationManager
Dim swChildModel                                        As SldWorks.ModelDoc2
Dim swOpenModel                                         As SldWorks.ModelDoc2
Dim swChildCustPropMngr                                 As CustomPropertyManager
Dim swChildModelDocExt                                  As ModelDocExtension
Dim swsheetmetal                                        As SldWorks.SheetMetalFeatureData
Dim swFeat                                              As SldWorks.Feature
Dim swBody                                              As SldWorks.Body2
Dim Sheet_metal                                         As Boolean
Dim Boolstatus                                          As Boolean
Dim Thickness                                           As Double
Dim conv                                                As Double
Dim i                                                   As Long
Dim loptions                                            As Long
Dim lerrors                                             As Long
Dim sPadStr                                             As String
Dim FilePath                                            As String
Dim FileName                                            As String
Dim swThkDir                                            As String
Dim swMatDir                                            As String
Dim swCurrent                                           As String
Dim RefCfg                                              As String
Dim ChildConfigName                                     As String
Dim sMatName                                            As String
Dim sMatDB                                              As String
Dim exFileName                                          As String
Dim Bodies                                              As Variant
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
    If swChildComp.ExcludeFromBOM Then GoTo Skip
Active:
'Layer
swApp.SetUserPreferenceToggle swUserPreferenceIntegerValue_e.swDxfOutputNoScale, 1
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDxfMapping, True
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDXFDontShowMap, True
swApp.SetUserPreferenceStringListValue swUserPreferenceStringListValue_e.swDxfMappingFiles, "D:\Solidworks\000_Aufträge\Solidworks 2016\Layereinstellungen\SW16Layer.txt"
index = swApp.GetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMappingFileIndex)
    If (index = -1) Then
        swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfMappingFileIndex, 0
'Layer
Set swChildModel = swChildComp.GetModelDoc2
    If (swChildModel.GetType <> swDocPART) Then GoTo Jump
    Set swpart = swChildModel
    FilePath = Left(swComp.GetPathName, InStrRev(swComp.GetPathName, "\") - 1)
    FileName = swChildModel.GetTitle
    swCurrent = swChildComp.ReferencedConfiguration
    Bodies = swpart.GetBodies2(swBodyType_e.swAllBodies, True)
    Set swBody = Bodies(0)
        If swBody.IsSheetMetal = 0 Then
        GoTo Jump
    If swBody.IsSheetMetal = 1 Then
    Debug.Print "Processing component " & FileName & " as a sheet metal component"
    Debug.Print "Current Config is : "; swCurrent
    GoTo Process
Process:
sMatName = swpart.GetMaterialPropertyName2(swCurrent, sMatDB)
    If sMatName = "" Then sMatName = "None"
    Debug.Print " Current material is : "; sMatName
    Set swFeat = swChildModel.FirstFeature
    While Not swFeat Is Nothing
        If swFeat.GetTypeName = "SheetMetal" Then
        Set swsheetmetal = swFeat.GetDefinition
        Thickness = swsheetmetal.Thickness
        conv = 1000
        Thickness = Thickness * conv
        Debug.Print " Thickness is :"; Thickness; "mm"
Set swFeat = swFeat.GetNextFeature
Wend
swMatDir = FilePath & "\" & sMatName
Debug.Print swMatDir
    If Dir(swMatDir, vbDirectory) = "" Then MkDir swMatDir
    swThkDir = FilePath & "\" & sMatName & "\" & Thickness
    Debug.Print swThkDir
        If Dir(swThkDir, vbDirectory) = "" Then MkDir swThkDir
        exFileName = FilePath & "\" & sMatName & "\" & Thickness & "\" & FileName & "-" & swCurrent
        Debug.Print exFileName
        Set swOpenModel = swApp.ActivateDoc3(swChildModel.GetPathName, True, loptions, lerrors)
        Boolstatus = swChildModel.ShowConfiguration2(swCurrent)
        swChildModel.ExportFlatPatternView exFileName & ".DXF", 1
        swApp.CloseDoc (swChildModel.GetPathName)
        GoTo Jump
Skip:
Debug.Print "Skipped"
Jump:
TraverseComponent swChildComp, nLevel + 1
Next i
