RRRam R.20/12/2018
Hi guys,
Here is a problem I spent an hour trying to solve, and couldn't do it. Maybe you'll have an idea.
I have this cylinder/tube:
See the cut at the top? It almost looks like an angled plane, but it isn't. It's an ellipsoid or something, it was caused by taking a cut of a bigger and more complex model that I won't go into.
Long story short, I want to make a true angled plane cut on that cylinder, that's going to be as close as possible to the complex cut. (i.e. an approximation.)
I was basically thinking, take the highest point of the cut and the lowest point of the cut. Make a line between them, and a line from each of them to the flat bottom of the cylinder. Take the plane that intersects the two points and is perpendicular to the plane defined by the 3 lines.
But, I don't know how to define in solidworks "The highest point in the cut". I want the point in the circumference of the cut that's the farthest away from the base of the cylinder. How can I mark that point in Solidworks?
Thanks for your help,
Ram Rachum.
