I have a case I need to replace multiple details in an assembly with a known set of replacement parts. I would like to either select the parts from the feature tree or the model window. Files are in a known path. (Attached zip has reference part files & assembly file)
This version, selection is only handled from the feature tree
My issue is …if I select any 1 single file it works fine, if I select more than 1 file the macro runs, but replace ALL parts with the same part.
Example
Original files
PartA-1
PartA-2
PartA-3
Replace With
PartB-1
PartB-2
PartB-3
Macro of what i have is below...
Option Explicit
Option Compare Text
Dim activeModel As SldWorks.ModelDoc2
Dim swSelComp As SldWorks.Component2
Dim swSelModel As SldWorks.ModelDoc2
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim sPadStr As String
Dim i As Long
Dim CfgName As String
Dim FileName As String
Dim bRet As Boolean
Dim nErrors As Long
Dim ret As Long
Dim swCompModel As ModelDoc2
Dim boolstatus As Boolean
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim IsToolBoxPart As Boolean
Sub mainA()
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
boolstatus = swApp.SetUserPreferenceDoubleValue(swUserPreferenceDoubleValue_e.swViewTransitionHideShowComponent, 0)
Dim LWerrors As Long
LWerrors = swModel.ResolveAllLightWeightComponents(False)
If swModel Is Nothing Then
MsgBox "No active Assembly document"
Exit Sub
If swModel.GetType <> 2 Then
Exit Sub
If swSelMgr.GetSelectedObjectCount2(-1) = 0 Then
MsgBox "No selected component", vbExclamation
Exit Sub
Dim selCount As Integer
selCount = swSelMgr.GetSelectedObjectCount2(-1)
selCount = selCount - 1
Dim i As Integer
For i = 0 To selCount
Set swSelComp = swSelMgr.GetSelectedObject6(i + 1, -1)
Set swCompModel = swSelComp.GetModelDoc2
Debug.Print swSelComp.Name2
If swSelComp.IsSuppressed = False Then
ret = swCompModel.Extension.ToolboxPartType
If ret <> 0 Then
MsgBox "Part selected is NOT a fastener", vbExclamation
Exit Sub
If ret = 0 Then
FileName = ""
CfgName = ""
CfgName = swSelComp.ReferencedConfiguration
If InStr(swSelComp.Name2, "PartA-1") Then
FileName = "C:\Test Data\REF Package\PartB-1.sldprt"
If InStr(swSelComp.Name2, "PartA-2") Then
FileName = "C:\Test Data\REF Package\PartB-2.sldprt"
If InStr(swSelComp.Name2, "PartA-3") Then
FileName = "C:\Test Data\REF Package\PartB-3.sldprt"
bRet = swAssy.ReplaceComponents2(FileName, CfgName, False, 0, True)
FileName = ""
CfgName = ""
Next
