Hi all,
Good luck to all, firstly.
I've created a simple profile and a path(helix) for a thread (with swept cut), which doesn't work.
Can anybody help on this?
Have a nice day/night/afternoon, anyways
Thnx,
Moshe.
Hi all,
Thnx,
Moshe.
Hi my friend,
Can you send me the corrected file? I must run out shopping and will try it bit later.....(and if you can save as 2015 file if relevant)
Si Solutions - you would be better off correcting your sketch and learning what works then having someone send you a model... just sayin
Hi all,
I managed to do it, but still didn't understand what were the messages on "bodies to keep" etc. Reminded me when I had a circular pattern and I had to check merge bodies and I don't think it was an option here so didn't get why the "keep bodies" thing showed up.
In any ways, I'd like to THANK YOU ALL for being so wonderful, G_D bless you,
Moshe.
Si Solutions
You need to change your sketch Cut Profile or make the Helix Pitch a little bigger - the sketch overlaps
