Macro Won't update properties from current configuration for saving .pdf. How do I get the file name to match the correct properties?
Question asked by Ben Bilbrough on Dec 17, 2018
Latest reply on Dec 17, 2018 by Deepak Gupta
I have a macro to save an .x_t and a STEP file and it works with a part with multiple configurations. I have a similar macro to save a .pdf, but it doesn't always work with configurations. It works initially, but if I change the configuration of the drawing views, the custom properties that are pulled are not always for the current configuration.
This is my current macro for the .pdf It has a little debugging
' C:\Users\bilbroughb.TRESKE\AppData\Local\Temp\swx12456\Macro1.swb - macro recorded on 09/19/18 by bilbroughb
Option Explicit
Dim Part As Object
Dim boolstatus As Boolean
Dim sRevision As String
Dim sPartNo As String
Dim swView As SldWorks.View
Dim swCustProp As CustomPropertyManager
Dim Config As SldWorks.Configuration
Dim cfg As String
Set swDraw = swApp.ActiveDoc
'Set swSelMgr = swModel.SelectionManager
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
Set swCustProp = swModel.Extension.CustomPropertyManager(swView.ReferencedConfiguration)
Set Config = swModel.GetActiveConfiguration
cfg = swModel.GetActiveConfiguration.Name
Dim testdefault As String
Dim testcfg As String
If cfg = "default" Then
sRevision = swModel.CustomInfo("Revision")
sPartNo = swModel.CustomInfo("Partno")
testdefault = 1
If cfg <> "default" Then
sRevision = swModel.GetCustomInfoValue(cfg, "Revision")
sPartNo = swModel.GetCustomInfoValue(cfg, "PartNo")
testcfg = 1
'Set swDraw = swApp.ActiveDoc
Set Part = swApp.ActiveDoc
Debug.Print "cfg" + ":" + " " + cfg
Debug.Print "sPartNo" + ":" + " " + sPartNo
Debug.Print "sRevision" + ":" + " " + sRevision
Debug.Print "testdefault" + ":" + " " + testdefault
Debug.Print "testcfg" + ":" + " " + testcfg
' Save As
longstatus = Part.SaveAs3("C:\Users\bilbroughb.TRESKE\Desktop\A working Folder\" + sPartNo + "_" + sRevision + ".PDF", 0, 0)
Here is the macro that works for the .x_t and Parasolid
Option Explicit
Dim Part As Object
Dim swCompModel As SldWorks.ModelDoc2
Dim value As String
Dim cfg As String
Dim Test As String
Set swModel = swApp.ActiveDoc
If cfg <> "Default" Then
If cfg = "Default" Then
Debug.Print "Test" + ":" + " " + Test
' Save As
longstatus = Part.SaveAs3("N:\CAD_Transfer\" + sPartNo + "_" + sRevision + ".x_t", 0, 0)
longstatus = Part.SaveAs3("N:\CAD_Transfer\" + sPartNo + "_" + sRevision + ".step", 0, 0)
