2 Replies Latest reply on Dec 18, 2018 5:04 PM by Philip Dannug
    Export to DXF/DWG - Scaling problems - 2018 SP4.0
    Philip Dannug
      I'm trying to create a DWG of a flat pattern but the scaling is coming out wrong. When imported back into Solidworks or opened in eDrawings, the scaling is 12:1. These same parts exported to DWGs just fine a few weeks ago.
      My process is:
      Right click bent sheet metal part, select Flatten
      Right click face of flat pattern, select Export to DXF/DWG
      Save as DWG
      I went into the Options menu from the Save As window and the Scale Output 1:1 section is greyed out.
