Tried voting for RD allocation and saw this:
Which administrator do I contact?
I tried different browsers. Any ideas?
Matthew Lorono can probably help.
John Stoltzfus wrote:
According to Matthew Lorono - You need to vote on the RD Allocation before you can Vote on the Top Ten List
Is that right Matthew????
Peter De Vlieger wrote:
So where do I find that RD allocation one ?
Because one can't vote on anything else unless one does that one but I can't see where I could find that one to begin with.
This site should do it: SOLIDWORKS World 2019 Top Ten List
So if one doesn't get the actual link handed then one has to go and search for it, if one knows that the search terms should be'top ten page'
which takes one to :
https://forum.solidworks.com/message/914646?q=top%20ten%20page
where one then is supposed toknow to click on the first available link
where one then has to figure out to click on the banner on top of the page
to finally get to the REQUIRED item to vote on
BEFORE one can actually vote on any of the suggestions
Am I the only one that finds that a bit rich?
How the heck is one supposed to find that if one isn't 24/7 on the forum?
Is it a sneaky way to avoid having people actually vote on anything or what ?
Frederick,
Thank you for pointing that out.
The fact remains how one is supposed to know exactly that one is supposed to go to that link so as to be able to vote on an item that isn't one of the proposed ideas? Put yourself in the shoes of someone that only occasionally visits or is even a new user. Is expecting that one click on each link really the best user experience they could come up with?
I frequent the forum often and I must admit I didn't see that link on the left side because I don't have the tendency to re-read every link in a column that normally only has links that don't change. Now I know that every year around this time, they add a link, briefly mind you, that gets removed after the voting because it's no one's business to keep track of what actually got voted as the top 10.
I had to restart my computer then when it booted up go straight and vote. They put a firewall restriction on my computer and that is the only way I could beat the system.
