Hi
Sometimes I get run-time error '10' 'The array is fixed or temporarily locked'
In the line> names = swCustPropMgr.GetNames
In the code I loop throw a lot of files, and scan all the properties in each part.
Can anybody help ?
BR Niels
Dim names As Variant
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
It might be due to fact the property array from previous file is being read while macro jumps on the next one. So you might want to clear the array once a file has been finished processing. If you can share up the full code, someone might be able to put up a better answer/solution.
