OK... here's the result of my troubleshooting...
This is happening pretty regularly on multiple machines...
A part is examined using the DFM wizard; the analysis completes fine, and a small tree of pass/fail elements is created.
However
If a 'failed' element is clicked on, SW will freeze for about 5 seconds, then disappear entirely.
What I have found, though, is that if I suppress all holes created with the hole wizard, then the DFM wizard will work fine.
However
SW crashes and automatically launches 'SolidWorks Rx'; after creating a nice little zip file, it says "Send this file to your technical support representative", along with a link to "Click here to contact tech support".
When I "click here", I get a web page like this, whether in Firefox, Opera, Chrome, IE, or Safari :
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
The requested scope CLIENT has not been enabled.
Before CLIENT variables can be used, the CLIENT state management system must be enabled using the cfapplication tag.
Resources:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.7) Gecko/2009021910 Firefox/3.0.7
Remote Address 168.75.115.196
Referrer
Date/Time 18-Mar-09 04:41 PM
