Anyone have a way to search with a query or programming in PDM to find the folders and files which are causing this error 'path is too long' to appear on 'Get Latest Version'?
Sincerely
Dwayne Parrott CSWP, SolidWorks Instructor and Support technician
This issue is due to the windows limitation of having a path length less than or equal to 256 characters. SWPDM does not track the lenght of the Path and actually only records the path starting at the folder in the root folder of the vault. So, if someone saves a file to a local view like: c:\OurVault with a path+filename that approaches the 256 character limit they will be able to check it in and access it with no issues.
On the other hand if someone else happens to have their local view saved to C:\Users\UserName\AppData\Roaming\SolidWorks\LocalViews\OurVault then they would not be able to access that file because Windows could not process the name.
The only thing I can think of would be to create an SQL script that looks through the Projects table of the database for any Path value that is over 230 characters long. That would help you narrow the search down to specific files.
You should also try and standardize everyone on the same location of the local view so that you don't run into this in the future.
Edited to add a sample SQL query:
SELECT
CASE WHEN LEN(Path) >= 230
THEN Path
ELSE 'value less than specified length'
END As Suspect_File_Paths
FROM dbo.Projects
***Noticed that I had the "Then" and "Else" statements backwards - It is fixed now.
You can change the path length, I just picked that as a starting point.
