Glenn Schroeder
My Favorite Ideas for SWW 2019
Discussion created by Glenn Schroeder on Dec 13, 2018
Latest reply on Jan 18, 2019 by Daen Hendrickson
Only some of these are ones I submitted, and I didn't put all the ones I submitted in this list.  They're in no particular order.  I know it's a long list; there were a lot of good Ideas submitted this year.
Drawings: Need better UI for adding welding symbols in drawings
Enable the Quick Mate Toolbar for Editing Mates
Automatic Direction Change on Extruded Cut
Allow Showing Tangent Edges for Selected Components in a Drawing View
Allow Linking BOM Columns Directly to Cut List Properties
Ability to read the Material, Weight, Surface, etc. from SOLIDWORKS Parts and Assembly without any Custom Property
Drawings:  Have Note Leaders Snap to Vertical and Horizontal
Add Balloon, Weld, and Note Leader Soft Snap similar to Dimensions
Have the Relation Toolbar Available in Drawings
Group drawing views
Have Default Layer Setting for Virtual Sharps in Options
Link to Property, Pin Dialog Box
Add Options to the Quick Mate Toolbar
When suppressing a feature in a component optionally rebuild the children features as erroneous, do not suppress them as well
Allow Entering Custom Value in Quick Scale List
Ability to override document dual dimension placement per dimension
Assemblies:  Patterned Components Should Keep Parent Configuration
Visibility settings should be system settings, not document settings
Highlight Component in Tree when Edge or Vertex is Selected
Provide entitlement to all Service Packs (SP5.0), regardless of purchase anniversary
Allow Midpoint Selection of Cylindrical Ends
Drawing: Option to delete child views when deleting a parent view
Option to Hide New Sketches in Display States
Drawing: Option to link drawing sheet name to model file name, configuration name or properties
"Center in Slot" Default Condition for Slot Mates
Fix UI so drop down boxes don't obscure the interface
Fix the Workflow Inconsistencies Between Mirroring and Linear Patterning in Assemblies
Drawings: Allow Centermark ends to extend radially an equal distance
Allow Midpoint Selection with Quick Mates
Drawing: Option to add/link Custom Properties/Dimensions in Dimensions
Fully Define Hole Wizard Slots
Setting for Leader Location in Multi-line Notes and Dimensions
Sketching:  Add 45° Sketch Relation
Fix the "Seed Position" Issue on Pattern Driven Component Patterns
Drawings:  Increase the Line Format toolbar functions
Easier Deleting of Dimensions with Instant 2d
Expand "Lock Concentric Mates"
Edited to add Manage Display States (especially Hide/Show) with Tables  (I don't know how this one got past me earlier.)
(2018-12-27 edit:  Automatic Direction Change on Extruded Cut is currently sitting at #6.  After all these years, I have some hope that one of my ideas will finally make the Top Ten.)
