I'm trying to offset a section of pipe using two 45 degree elbows. I've attached a test sketch, I have two sketches one uses a plane and it works as I need it to, the second is trying to use a 3D sketch however no matter what I try it keeps saying it's over defined. Anyone know how to make this work?
I deleted these in blue: radius dim, angle dim, colinear.
I added coincident from the upper line to the point below (replacing colinear).
I set both arcs to equal (replacing deleted radius dim).
To check the design, I placed a reference dim where the angle dim was. Though driven, it checks as 45.00º.
