CBCasey Balderson12/12/2018
I have a series of Library Feature Parts that I would like to assign to buttons in the Command Manager under a custom tab. This is because the Design Library itself is so overwhelmed with folder structure, that it doesn't make sense to bury it in there. Also, I intend to convert these into Macro Features in the future, so having the buttons already assigned and visible would be an easy transition in the future as well (once I get more comfortable with Macro Features).
It doesn't seem that the "Record Macro" gives me any useful information, as just opens the library feature part, and does nothing with it.
As of now, by VBA code generates the LFP, but chooses the settings automatically based on last saved. I want the Property Manager to show and allow you to choose the placement plane, configuration, and references.
Option Explicit
Option Compare Text
    Dim myFeat As Feature
    Dim myEnt As Entity
    Dim mySelectData As SelectData
    Dim selMgr As SelectionMgr
    Dim libPart As ModelDoc2
    Dim myLibFile As String
    Dim Part As ModelDoc2
    Dim myPart As PartDoc
    Dim boolStatus As Boolean
    myLibFile = "C:\Users\cbalderson\Desktop\lib\BEAD_20DEG.SLDLFP"
    Set Part = swApp.ActiveDoc
    boolStatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
    Part.InsertLibraryFeature myLibFile
PS. I referenced " " for the code I have now.
