I'm working with a large assembly and after I rebuild the entire assembly turns red. Rebuilding again does not revert the colors back to normal. Closing out of SW and reopening shows the assembly with the proper coloring, but as soon as I rebuild again everything turns red. Any thoughts?
If you click on the screen does that change? If you click the assembly top level in the tree and then click somewhere else does it change?
Steve C
