I have gotten into the habit of running spell check, and when I do, every time I get a hit on a word I get this error message. It took me while to determine that it was coming from spell check because the error message would pop up behind a window that I had open and I wouldn't see it for maybe hours later when I stumbled upon it.
This is the error message:
when I click on the show help button, I get this very unhelpful window:
when I clear the error message (hitting the OK button, or the red X in the upper right corner), it opens a blank word doc. which I then have to close. this takes a bit of time to clear all of these messages and is quite annoying.
Anyone have any thoughts on this?
Just have to ask are you importing in notes from word or another word processing program. If so its telling you to check before importing it.
If you are using Solid Works to add a note I have never had that happen and I use spell check all the time.
