Hello all,
I'm still trying to get better with the loft feature, half the time i try to use some curves to guide the loft feature i do something wrong and the feature fails. Inside the attachment you can find my most recent attempt to figure it out but i still have no idea about whats wrong with it. I got two similar profiles parallel to each other with same amount of corners and some spline curves in between connecting these two profiles from corner to corner. Loft feature works just fine as long as i dont select any guide curves. Can someone explain to me what i am doing wrong when it comes to guide curves?
Hi Gencosman.
I used skecth 1 and 2 for direction 1.
Direction 2, RMB and select selection manager, so you will be able to select one line at the time in 3D sketch.
Guide curves as i experience it, should have their own sketch - but you can use the selection manager as a work around
Hope this helps
