Is there a way to have the yes/no selector in the property tab builder default to caps instead of lower case. I'm currently populating my BOM with the lower case version and then manually changing it to caps.
That's pretty much what I'm doing now. I just wondered if it could be caps by default when you set up the property tab builder using the yes/no selector.
Set your Drafting Standards to
Then Save the Drafting Standards - then it will retain All Uppercase
