PDM Add-in Check in can't  catch
Question asked by Pichaiyan Prabaharan on Dec 10, 2018
Latest reply on Dec 10, 2018 by Lee CS Young
I'm testing a  find actions sample code(Refer Below) from SolidWorks help.
In that I able to catch all options expect Check-In.
May I know what is the issue ?
Imports EdmLib
Public Class Class1
    Implements IEdmAddIn5
    Public Sub GetAddInInfo(ByRef poInfo As EdmAddInInfo, poVault As IEdmVault5, poCmdMgr As IEdmCmdMgr5) Implements IEdmAddIn5.GetAddInInfo
        'Specify add-in information
        poInfo.mbsAddInName = "My first add-in"
        poInfo.mbsCompany = "The name of my company"
        poInfo.mbsDescription = "This is a very nice add-in."
        poInfo.mlAddInVersion = 1
        'Specify minimum version of SOLIDWORKS Enterprise PDM
        poInfo.mlRequiredVersionMajor = 5
        poInfo.mlRequiredVersionMinor = 2
        'Notify when a file has been added
        poCmdMgr.AddHook(EdmCmdType.EdmCmd_PostAdd)
        'Notify when a file has been checked out
        poCmdMgr.AddHook(EdmCmdType.EdmCmd_PostLock)
        'Notify when a file is about to be checked in
        poCmdMgr.AddHook(EdmCmdType.EdmCmd_PreUnlock)
        'Notify when a file has been checked in
        poCmdMgr.AddHook(EdmCmdType.EdmCmd_PostUnlock)
    Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As Array) Implements IEdmAddIn5.OnCmd
        'Check the type of hook that triggered this call
        Dim name As String
        Select Case poCmd.meCmdType
            Case EdmCmdType.EdmCmd_PostAdd
                name = "PostAdd"
            Case EdmCmdType.EdmCmd_PostLock
                name = "PostLock"
            Case EdmCmdType.EdmCmd_PreUnlock
                name = "PreUnlock"
            Case EdmCmdType.EdmCmd_PostUnlock
                name = "PostUnlock"
            Case Else
                name = "?"
        End Select
        'Check the upper and lower bounds of the array
        Dim message As String
        message = ""
        Dim index As Long
        index = LBound(ppoData)
        Dim last As Long
        last = UBound(ppoData)
        'Append the paths of all files to a string
        While index <= last
            message = message + ppoData(index).mbsStrData1 + vbLf
            index = index + 1
        End While
        'Display a message to the user
        message = "The following files were affected by a " + name + " hook:" + vbLf + message
        Dim vault As EdmVault5
        vault = poCmd.mpoVault
        vault.MsgBox(poCmd.mlParentWnd, message)
End Class
