Loading Form with PDM Event
Question asked by Pichaiyan Prabaharan on Dec 11, 2018
Latest reply on Dec 11, 2018 by Simon Turner
HI,
I'm trying to load a form when checkout a file from vault.
And I tested with sample code as shown as below.
Imports EdmLib
Public Class Class1
Implements IEdmAddIn5
Public name As String
Public Sub GetAddInInfo(ByRef poInfo As EdmAddInInfo, poVault As IEdmVault5, poCmdMgr As IEdmCmdMgr5) Implements IEdmAddIn5.GetAddInInfo
'Specify add-in information
poInfo.mbsAddInName = "My first add-in"
poInfo.mbsCompany = "The name of my company"
poInfo.mbsDescription = "This is a very nice add-in."
poInfo.mlAddInVersion = 1
'Specify minimum version of SOLIDWORKS Enterprise PDM
poInfo.mlRequiredVersionMajor = 5
poInfo.mlRequiredVersionMinor = 2
'Notify when a file has been added
poCmdMgr.AddHook(EdmCmdType.EdmCmd_PostAdd)
'Notify when a file has been checked out
poCmdMgr.AddHook(EdmCmdType.EdmCmd_PostLock)
'Notify when a file is about to be checked in
poCmdMgr.AddHook(EdmCmdType.EdmCmd_PreUnlock)
'Notify when a file has been checked in
poCmdMgr.AddHook(EdmCmdType.EdmCmd_PostUnlock)
Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As Array) Implements IEdmAddIn5.OnCmd
'Check the type of hook that triggered this call
Select Case poCmd.meCmdType
Case EdmCmdType.EdmCmd_PostAdd
name = "PostAdd"
Case EdmCmdType.EdmCmd_PostLock
name = "PostLock"
'Initiate the Form Here
Dim myform As New Form1
myform.ShowDialog()
Case EdmCmdType.EdmCmd_PreUnlock
name = "PreUnlock"
Case EdmCmdType.EdmCmd_PostUnlock
name = "PostUnlock"
Case Else
name = "?"
End Select
'Check the upper and lower bounds of the array
Dim message As String
message = ""
Dim index As Long
index = LBound(ppoData)
Dim last As Long
last = UBound(ppoData)
'Append the paths of all files to a string
While index <= last
message = message + ppoData(index).mbsStrData1 + vbLf
index = index + 1
End While
'Display a message to the user
'message = "The following files were affected by a " + name + " hook:" + vbLf + message
Dim vault As EdmVault5
vault = poCmd.mpoVault
vault.MsgBox(poCmd.mlParentWnd, message)
End Class
And I want to load the below form to get output value. In the text box I want to show up the results ("name").
Form Codes :
Public Class Form1
Dim callClass As New Class1
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
Me.Close()
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
TextBox1.Text = callClass.name
End Class
its loading a form successfully. But once I click the button "Get Value" Nothing I get.
Could you please anyone help with this issue?.
Thanks a lot
