hello
Here my configuration
Modèle cpu : Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Linux obelix2 4.18.0-3-amd64 #1 SMP Debian 4.18.20-2 (2018-11-23) x86_64 GNU/Linux
buster/sid
Vidéo : VGA compatible controller [0300]: NVIDIA Corporation GM107GL [Quadro K620]
Version logiciel DAO : draftSight V 2018.3.0.4215
Here my pb :
Following my last upgrade system the software draftSight from Dassault which functioned perfectly before opens and is closed suddenly.
To trace Pb, I launched in a terminal the following order:
strace /opt/dassault-systemes/DraftSight/Linux/DraftSight
openat(AT_FDCWD, "/opt/dassault-systemes/DraftSight/Linux/../Libraries/libpixman-1.so.0", O_RDONLY|O_CLOEXEC) = 87
read(87, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\244\0\0\0\0\0\0"..., 832) = 832
fstat(87, {st_mode=S_IFREG|0644, st_size=677904, ...}) = 0
writev(2, [{iov_base="Inconsistency detected by ld.so:"..., iov_len=33}, {iov_base="../elf/dl-tls.c", iov_len=15}, {iov_base=": ", iov_len=2}, {iov_base="73", iov_len=2}, {iov_base=": ", iov_len=2}, {iov_base="_dl_next_tls_modid", iov_len=18}, {iov_base=": ", iov_len=2}, {iov_base="Assertion `", iov_len=11}, {iov_base="result <= GL(dl_tls_max_dtv_idx)"..., iov_len=36}, {iov_base="' failed!\n", iov_len=10}], 10Inconsistency detected by ld.so: ../elf/dl-tls.c: 73: _dl_next_tls_modid: Assertion `result <= GL(dl_tls_max_dtv_idx) + 1' failed!) = 131
exit_group(127) = ?
+++ exited with 127 +++
I proceeded to an uninstalling the version 2018.2.0.3102 after having downloaded the last version 2018.3.0.4215 then I proceeded to D installation, without success.
I checked that all the libraries were available as follows:
ldd /opt/dassault-systemes/DraftSight/Linux/DraftSight
linux-vdso.so.1 (0x00007ffc0e385000)
libTD_Db.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_Db.so (0x00007f27845a9000)
libTD_DbRoot.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_DbRoot.so (0x00007f2784310000)
libTD_Gs.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_Gs.so (0x00007f2783ea7000)
libTD_Gi.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_Gi.so (0x00007f278393f000)
libTD_Ge.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_Ge.so (0x00007f2783470000)
libTD_Root.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_Root.so (0x00007f2783129000)
libTD_Alloc.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libTD_Alloc.so (0x00007f2782f24000)
libAecGeometry.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libAecGeometry.so (0x00007f2782b6f000)
libFXExport.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFXExport.so.1 (0x00007f27827a0000)
libFXRenderBase.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFXRenderBase.so.1 (0x00007f27821bb000)
libFXCommandsBase.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFXCommandsBase.so.1 (0x00007f278145b000)
libFxFileDialogs.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFxFileDialogs.so.1 (0x00007f278123e000)
libDDKERNEL.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libDDKERNEL.so.1 (0x00007f2780a20000)
libFxImages.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFxImages.so.1 (0x00007f2780811000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f27807ec000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f27806ab000)
libFXCrashRpt.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFXCrashRpt.so.1 (0x00007f2780484000)
libFXLISP.so.1 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libFXLISP.so.1 (0x00007f27801f3000)
libQt5Widgets.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libQt5Widgets.so.5 (0x00007f277fb6e000)
libQt5X11Extras.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libQt5X11Extras.so.5 (0x00007f277fb69000)
libQt5Gui.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libQt5Gui.so.5 (0x00007f277f5ad000)
libQt5Network.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libQt5Network.so.5 (0x00007f277f453000)
libQt5Xml.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libQt5Xml.so.5 (0x00007f277f416000)
libQt5Core.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libQt5Core.so.5 (0x00007f277eec8000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f277eea5000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f277ed22000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f277eb8e000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f277eb74000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f277e9b7000)
libTD_SpatialIndex.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libTD_SpatialIndex.so (0x00007f277e7a5000)
libsisl.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libsisl.so (0x00007f277e421000)
libTD_Dwf7Export.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libTD_Dwf7Export.so (0x00007f277e172000)
libcups.so.2 => /usr/lib/x86_64-linux-gnu/libcups.so.2 (0x00007f277e0df000)
libQt5PrintSupport.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libQt5PrintSupport.so.5 (0x00007f277e071000)
libQt5Svg.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libQt5Svg.so.5 (0x00007f277e018000)
libTD_Br.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libTD_Br.so (0x00007f277dde8000)
libQt5OpenGL.so.5 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libQt5OpenGL.so.5 (0x00007f277dd8f000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007f277dcfb000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f277dcb5000)
/lib64/ld-linux-x86-64.so.2 (0x00007f2785c85000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f277dc89000)
libgobject-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007f277dc35000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f277db18000)
libicui18n.so.52 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libicui18n.so.52 (0x00007f277d711000)
libicuuc.so.52 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libicuuc.so.52 (0x00007f277d398000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f277d38c000)
libDwfToolkit.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/../Libraries/libDwfToolkit.so (0x00007f277cc60000)
libW3dTk.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/../Libraries/libW3dTk.so (0x00007f277c904000)
libWhipTk.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/../Libraries/libWhipTk.so (0x00007f277c605000)
libDwfCore.so => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/../Libraries/libDwfCore.so (0x00007f277c2c1000)
libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007f277c272000)
libgnutls.so.30 => /usr/lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007f277c104000)
libavahi-common.so.3 => /usr/lib/x86_64-linux-gnu/libavahi-common.so.3 (0x00007f277c0f6000)
libavahi-client.so.3 => /usr/lib/x86_64-linux-gnu/libavahi-client.so.3 (0x00007f277c0e3000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f277bec5000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f277be8f000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f277bdd2000)
libfreetype.so.6 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libfreetype.so.6 (0x00007f277bb2f000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f277baf2000)
libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f277bae9000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f277b8e5000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f277b6dd000)
libffi.so.6 => /usr/lib/x86_64-linux-gnu/libffi.so.6 (0x00007f277b6d3000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f277b65f000)
libicudata.so.52 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/libicudata.so.52 (0x00007f2779df2000)
libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007f2779d15000)
libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007f2779cdf000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007f2779cd9000)
libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007f2779ccb000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007f2779cc5000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f2779cac000)
libp11-kit.so.0 => /usr/lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007f2779b7d000)
libidn2.so.0 => /usr/lib/x86_64-linux-gnu/libidn2.so.0 (0x00007f2779b5c000)
libunistring.so.2 => /usr/lib/x86_64-linux-gnu/libunistring.so.2 (0x00007f27799d8000)
libtasn1.so.6 => /usr/lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007f27797c5000)
libnettle.so.6 => /usr/lib/x86_64-linux-gnu/libnettle.so.6 (0x00007f277958e000)
libhogweed.so.4 => /usr/lib/x86_64-linux-gnu/libhogweed.so.4 (0x00007f2779358000)
libgmp.so.10 => /usr/lib/x86_64-linux-gnu/libgmp.so.10 (0x00007f27790d4000)
libdbus-1.so.3 => /lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007f277907f000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f2778e6d000)
libpng12.so.0 => /opt/dassault-systemes/DraftSight/Linux/../Libraries/../Libraries/libpng12.so.0 (0x00007f2778c47000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f2778a30000)
libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f27789a4000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f277877c000)
liblz4.so.1 => /usr/lib/x86_64-linux-gnu/liblz4.so.1 (0x00007f277855f000)
libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f2778441000)
libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f277841f000)
impossible to locate the file "dl-tls.c",
find / -name "dl-tls.c" -print
Can you help me by giving me some tracks of research
Through reading several post english some on various forums where it was indicated to start as a mode administrator I ended up launching my command strace in sudo mode. Indeed I could finalize the table to record me and receive the e-mail of confirmation. Except that I always have this inopportune closing but this time with this error message:
It seems me to progress but it is hard.
