This is only happening with items from the solidworks vault (items with bolts for icons in the feature manager tree). For example, a 4-40 flat washer may show up with like a 1.75" OD. No one else's cpu is doing it so I figure it has to be a quick setting but I just can't find it. Has anyone encountered this before?
Ray
I did find one drawn-out, tedious, temporary fix. Right click on a part and select "Edit Toolbox Component". Pick what you want and all like hardware will update. However, this is not the root cause or a permanent solution. Any other ideas are welcome.
