13 Replies Latest reply on Dec 8, 2018 9:21 AM by Deepak Gupta
    Macro not Opening .sldprt for Proper .step Export
    Joseph Walden
      Edit Dec 7 2018,
      Credit for the original macro that I modified in the below thread goes to Artem Taturevych in the below thread:
      https://forum.solidworks.com/message/420553#comment-420553
      Running SW 2017
      I was excited to get a macro working (a first for me, I'm quote new) until I realized that it wasn't quite doing what I intended for .step (but it worked for .igs). Sigh...
      A frustrating issue I've had to deal with is making .step files from assemblies. The issue is that when you save from .sldasm files straight to .step format the resulting assembly does not keep the mechanical mates. Now the mates remain if the steps go as follows:
      - save .sldasm to .sldprt
      - open .sldprt
      - resave as .step
      It's been insisted that the mates remain and I was excited at first because the below macro did lock the mates for .igs (which I recall had a similar issue).
      I have tried #Task but this is having it's own issues to the Standard License, posted on a separate thread:
      #Task "Failed to Obtain a License of Solidworks Task Scheduler"
      First, is there a simple option for .step export that locks parts upon opening (like for Parasolid, .x_t)? I've been unable to find anything in SW or the forums. If not, then
      below is the macro at the moment:
      Dim fileerror As Long
      Dim filewarning As Long
          Set swModel = swApp.ActiveDoc
          If Not swModel Is Nothing Then
              Dim path As String
              path = swModel.GetPathName
              If path <> "" Then
                  Dim filename As String
                  filename = InputBox("Enter the CAD String")
                  SaveFile filename & ".sldprt"
                  SaveFile filename & ".x_t"
                  SaveFile filename & ".easm"
                  'Second Sub is to Lock Assembly Components into Place by opening the resaving the .sldprt file'
                  Dim filename2 As String
                  filename2 = filename & ".sldprt"
                  SaveFile2 filename & ".step"
      Sub SaveFile(filename As String)
          swModel.SaveAs4 filename, _
              swSaveAsVersion_e.swSaveAsCurrentVersion, _
              swSaveAsOptions_e.swSaveAsOptions_Copy, 0, 0
      Sub SaveFile2(filename As String)
          Set swModel = swApp.OpenDoc6(PathEnd + filename2, swDocPART, swOpenDocOptions_Silent, "", fileerror, filewarning)
      The macro does properly export .step files (no errors appear) but it appears to be saving the files from the assembly and not the opened part (as the OpenDoc6 line in SaveFile2 is intended to do). How do I get the Macro to properly open the .sldprt file and resave it as a .step?
      Many thanks in advance,
      Joseph
        • Re: Macro not Opening .sldprt for Proper .step Export
          Danniel Sims
          Joseph,
          I don't think there are any mates transferred with the export process.  Those file types have no method to carry the information.  I would check your settings for importing and exporting the filetypes.  If you only want a part, you may have to program user preference settings on export.  I export IGES, STL, STEP, and Parasolids for CADCAM information.  When they are imported back in to check for the coordinate system, only the STLs are parts.  Everything else pulls in as assemblies with sub-part components.  Those are just the settings I need for what I'm doing, you may be able to do something differently, you'd need to look atthe Import/Export settings for your filetypes.  If the assembly is ok and you just don't want things to move, you could cycle through the feature tree after import and fix all the items so they can't move.
          Check out SetUserPreferenceToggle  There are subsettings for import/export there.
              Joseph Walden
              Hello Danniel,
              Thank you for the reply.
              I've looked through the SetUserPreferenceToggle Page and there is oddly no option for STEP to export the components into a single file (which is available with IGS and STL).
              Same goes for the settings page under Options > System Options > Export > STEP. There is no check box for exporting components into a single file.
              Might there be some other system setting that I'm missing? Could this also be a result of still using SW 2017?
              Your response though makes it sound like if a CAD user downloads a STEP assembly that they should expect the mates originally put in place to no longer be present and that locking components manually in the feature tree is a common routine. Would you say that in your experience that this is common?
              Thanks again,
              Joseph
                  Danniel Sims
                  What I am doing is different than what you are trying to do... I actually need the parts to  be separate.  However, any time I receive a step file from a vendor for approval it is broken up into an assembly by Solid Works.  On my end, I use a macro to fix all the components where they are before I do anything.  I usually save out the file as a part file just for safety.  As a vendor's item, I don't need to keep all the sub parts around.  When you save the assembly as a part, the step chunks usually turn into surfaces, so when you re-save out the part as a step file it essentially is a single part.
                  Glad you got your answer though.
                Artem Taturevych
                Hi Joseph,
                Regarding #TASK - just uncheck the 'Background Mode' option in settings and it will work in Standard:
                Artem
                    Joseph Walden
                    Deepak,
                    Thank you for your reply.
                    Unfortunately this results in the same sort of STEP file. The file opens as an assembly and needs to open as a part.
                    Attached is an example exported STEP file from this morning with the above changes implemented. Is it possible that running SW 2017 may be affecting the results?
                    Thank you again,
                    Joseph,
                        Deepak Gupta
                        In you macro how are you defining the path? And issue should be version related.
                          Deepak Gupta
                          Joseph, try the following codes. I've tested the macro and it seems to be working fine for me.
                          Option Explicit
                          Dim path As String
                          Sub Main()
                                  If path <> "" Then
                                      path = Left(path, InStrRev(path, "\"))
                                      SaveFile path + filename & ".sldprt"
                                      SaveFile path + filename & ".x_t"
                                      SaveFile path + filename & ".easm"
                                      'Second Sub is to save Assembly as STEP file with all components in one file.
                                      filename2 = path + filename
                                      SaveFile2 filename2
                              swModel.SaveAs4 filename, swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Copy, 0, 0
                              Set swModel = swApp.OpenDoc6(filename & ".sldprt", swDocPART, swOpenDocOptions_Silent, "", fileerror, filewarning)
                              swModel.SaveAs4 filename & ".step", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Copy, 0, 0
                              swApp.CloseDoc filename & ".sldprt"
                              Kill filename & ".sldprt"
                              Joseph Walden
                              Deepak,
                              This works correctly and as wanted. Thank you for the help.
                              One minor change I made was removing
                              from line 39 as I still want to keep the .sldprt file after the macro is done running. Updated macro I have looks as follows:
                              Option Explicit
                              Dim path As String
                                      If path <> "" Then
                                          SaveFile2 filename2
                                  'save .easm, .sldprt, and .x_t files from the .sldasm file.'
                                  'Second Sub is to Lock Assembly Components into Place by opening and resaving the .sldprt file as a .STEP'
                              Thank you again. Much appreciated.
                              Joseph
                                Joseph Walden
                                Deepak,
                                I've encountered another problem. If the assembly has multiple configurations it only exports the .STEP file, which is very strange. If the assembly has only a default configuration then it works as expected.
                                Why am I not seeing the other file formats? I'm still prompted as expected for the .easm file but nothing shows up now.
                                Thank you,
                                Joseph
                                  Joseph Walden
                                  Deepak,
                                  Did more digging on the help page and managed to add lines along this example macro to call out the current assembly configuration.
                                  (declaration)
                                  Dim config As SldWorks.Configuration
                                  (usage)
                                      Set config = swModel.GetActiveConfiguration
                                  Macro is now this.
                                  Option Explicit
                                  Dim path As String
                                          If path <> "" Then
                                              SaveFile2 filename2
                                  Thank you again for all your help.
                                  Joseph,
