I'm able to successfully create a user defined part, but for instance I have a single terminal block which has "control" and "feedback" D-SUB connectors for multiple axes.
So I have Axis 1 Control, Axis 1 Feedback, Axis 2 Control, Axis 2 Feedback, etc.
When I do the terminal "marking" in the "circuits" wizard, is there a good way to name these different connectors?
Initially I've adopted the following convention for the "marking", but it is a bit cumbersome. Is there a better way?
Ax1CtrlAO+
Ax1CtrlAO-
Ax1FBEncA+
Ax1FBEncA-
etc.
Is there a better way to do the naming, or is there a way to specify sub-connectors on a device?
I'm happy to RTFM if someone can point me to an article, etc, but none of the tutorials or guides I have seen have mentioned this particular issue.
Thanks!
Wes
Wes, this is a great example of using "GROUP" to subdivide portions of a part. I name the terminals based solely on their part mark, and name the subdivided circuit GROUPS. When you add a group, it can be shown on a symbol that reflects that sub-group.
So for your example name the terminal AO+ and AO-, and give them the same "group" of Ax1Ctrl
