7 Replies Latest reply on Dec 6, 2018 4:11 AM by Dave Baxter
    Macro help
    Dave Baxter
      Hopefully I can explain this in a way that makes sense.
      I have been using a macro to export Sheet Metal Flat patterns from assemblies for a while now and I am trying to tweak the outputs (if possible).
      Basically I want to export as a PDF also but the view is normally (depending on the part size) larger than the output image. This is obviously the same with the less important but rather handy, 'windows preview' image. I believe what I need is to add a ZoomToFit command to the Macro but programming is not exactly my forte.
      The macro as it is now is below, can anyone even understand what I mean or even better help me add the command?
      I have researched this for quite a while now and just cannot find a simple answer.
      Thanks in advance
           Dave
          Option Explicit
          Dim MyCount As Integer
          Dim PartName(0 To 200) As String
         Dim swApp                       As SldWorks.SldWorks
         Dim swModel                     As SldWorks.ModelDoc2
         Dim swAssy                      As SldWorks.AssemblyDoc
         Dim swConf                      As SldWorks.Configuration
         Dim swRootComp                  As SldWorks.Component2
         Dim nStart                      As Single
         Dim bRet                        As Boolean
         Set swModel = swApp.ActiveDoc
         Set swConf = swModel.GetActiveConfiguration
         Set swRootComp = swConf.GetRootComponent3(True)
         TraverseComponent swRootComp, 1
      Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
      On Error Resume Next
      Dim vChildComp                  As Variant
         Dim swpart                      As SldWorks.PartDoc
         Dim swChildComp                 As SldWorks.Component2
         Dim swConfig                    As SldWorks.Configuration
         Dim swConfMgr                   As SldWorks.ConfigurationManager
         Dim swChildModel                As SldWorks.ModelDoc2
         Dim swOpenModel                 As SldWorks.ModelDoc2
         Dim swChildCustPropMngr         As CustomPropertyManager
         Dim swChildModelDocExt          As ModelDocExtension
         Dim swsheetmetal                As SldWorks.SheetMetalFeatureData
         Dim swFeat                      As SldWorks.Feature
         Dim swBody                      As SldWorks.Body2
         Dim Sheet_metal                 As Boolean
         Dim Boolstatus                  As Boolean
         Dim Thickness                   As Double
         Dim conv                        As Double
         Dim i                           As Long
         Dim loptions                    As Long
         Dim lerrors                     As Long
         Dim sPadStr                     As String
         Dim FilePath                    As String
         Dim FileName                    As String
         Dim swThkDir                    As String
         Dim swMatDir                    As String
         Dim swCurrent                   As String
         Dim RefCfg                      As String
         Dim ChildConfigName             As String
         Dim sMatName                    As String
         Dim sMatDB                      As String
         Dim exFileName                  As String
         Dim Bodies                      As Variant
         Dim k As Long
         vChildComp = swComp.GetChildren
         For i = 0 To UBound(vChildComp)
             Set swChildComp = vChildComp(i)
             'Check to see if current component is suppressed
             If swChildComp.IsSuppressed = False Then GoTo Active Else GoTo Skip
      Active:
      Set swChildModel = swChildComp.GetModelDoc2
         'Check to see if child component is an Assembly or part
         If (swChildModel.GetType <> swDocPART) Then GoTo Jump 'Skips Subassemby level
      Set swpart = swChildModel 'Applies part commands for current component
      FilePath = Left(swComp.GetPathName, InStrRev(swComp.GetPathName, "\") - 1)
      FileName = Left(swChildModel.GetTitle, InStrRev(swChildModel.GetTitle, ".") - 1) 'Get title of component
      swCurrent = swChildComp.ReferencedConfiguration 'Get current configuration of component
      'exclude same parts
      PartName(MyCount) = swChildModel.GetTitle & swChildComp.ReferencedConfiguration
      For k = 0 To MyCount
      If MyCount <> k Then
      If PartName(MyCount) = PartName(k) Then
      'part already exists
      GoTo Jump
      Next k
      If IsEmpty(swpart.GetBodies2(swBodyType_e.swAllBodies, True)) Then
      GoTo Jump
      Bodies = swpart.GetBodies2(swBodyType_e.swAllBodies, True)
      Set swBody = Bodies(0)
         If swBody.IsSheetMetal = 0 Then 'If Body is not sheet metal
                 GoTo Jump
         If swBody.IsSheetMetal = 1 Then 'If body is sheet metal
             GoTo Process
      Process:
      'Get Part Material
      sMatName = swpart.GetMaterialPropertyName2(swCurrent, sMatDB)
      If sMatName = "" Then sMatName = "DWG files"
      'Get part Thickness
      Set swFeat = swChildModel.FirstFeature
         While Not swFeat Is Nothing
         If swFeat.GetTypeName = "SheetMetal" Then
             Set swsheetmetal = swFeat.GetDefinition
             Thickness = swsheetmetal.Thickness
      Select Case swChildModel.LengthUnit
        Case "0" 'mm
            conv = 1000
           Thickness = Thickness * conv
          Case "2" 'm
            conv = 1
           Case "3" 'inches
            conv = 39.3700787401575
         End Select
      Set swFeat = swFeat.GetNextFeature
         Wend
      swMatDir = FilePath & "\" & sMatName
      If Dir(swMatDir, vbDirectory) = "" Then MkDir swMatDir
      swThkDir = FilePath & "\" & sMatName & "\" & Thickness
      If Dir(swThkDir, vbDirectory) = "" Then MkDir swThkDir
      exFileName = FilePath & "\" & sMatName & "\" & Thickness & "\" & FileName & "-" & swCurrent
      Set swOpenModel = swApp.ActivateDoc3(swChildModel.GetPathName, True, loptions, lerrors)
      Boolstatus = swChildModel.ShowConfiguration2(swCurrent)
      swChildModel.ExportFlatPatternView exFileName & ".DWG", 1
      swChildModel.ExportFlatPatternView exFileName & ".PDF", 1
      swApp.CloseDoc (swChildModel.GetPathName)
      MyCount = MyCount + 1
      GoTo Jump
      Skip:
      Jump:
             TraverseComponent swChildComp, nLevel + 1
                Next i
      MyCount = 0
        • Re: Macro help
          Deepak Gupta
          Dave, not on the system but add following line
          swChildModel.ViewZoomtofit2
          after
          and check if that works.
          Also reading your codes I'm wondering if you're actually getting the PDF saved using this line?
            • Re: Macro help
              Dave Baxter
              Thanks for the reply Deepak,
              I just added the line and it seemed to make no difference at all. Maybe I did something wrong?
              Regarding the PDF line, it seems that the problem I assumed was related might be a failure with an assumption I made.
              I am not sure if it makes a difference but, I basically changed .DXF to .DWG (in that line of code) and it worked. As in, I get a dwg file which seems fine in eviewer, draftsight and also with clients, but it does not have a preview in windows or, as I have found out just now (pointed out by yourself) the PDF does not export correctly either. I get the coordinate arrows in the PDF when there was nothing before though?
              I am double checking what I have said to make sure I am not giving you false info....
              I have tested with the 'test' assembly and for clarity have included the results. (I finally worked out that a zip file is allowed!! I think?)
              I did the simple parts different sizes to check the output size of the exported .DWG/.PDF. The .PDF obviously does not work which I apologise for as the actual job has very large cutouts, thus giving me a false flag.. and a blank preview.
              I am pretty sure it is a failure with me but ?
              I have edited some earlier text in this post to hopefully explain more specifically.
                • Re: Macro help
                  Deepak Gupta
                  There is no thumbnail for DXF file but yes there is for DWG (I've no clue why). So thumbnail can be added to the DXF file via macro which means DWG would be your option.
                  For PDF, the codes are not correct but those can be fixed. But are you looking for a PDF of folded part or flat pattern?
                    • Re: Macro help
                      Dave Baxter
                      That is the main reason for wanting to change the macro to .DWG export in the first place as it makes finding a file easier and quicker. Also I can see obvious problems with the flat pattern without opening anything. The reason for the PDF was mainly because I couldn't get the .DWG preview working. This was going to be my way of getting a preview.
                      I believe that the reason for no preview for a DXF is because they are not created with a thumbnail. This is the reason for DWG export. I have a macro for that but it doesnt work the way the macro I want to edit does and takes longer.
                      I was hoping that I could 'just' export to DWG and everything would be perfect but.......not that simple.
                        • Re: Macro help
                          Deepak Gupta
                          For me the exported DWG files (even the ones you've posted above) are showing the thumbnails perfectly. Are you seeing the thumbnail in your PDF files (even if it is blank)? If not then it may be the thumbnail setting under your folder options.
                          Also have you tried using the preview pane to see the preview of selected file?
                            • Re: Macro help
                              Dave Baxter
                              They do show up but they are 4 different sizes and through further testing (I should've explained this better) if you increase the sizes of the part they become larger than the preview. Yes the preview pane works fine on any other DWG export with other macros but I have many parts in assemblies that require DWG files so the assembly export is better and saves time. I have attached a modified set of parts to show the size increase. This is why I want a fit all command.
                              The actual parts I need are frames with 1000 x 2000 cutouts in the middle so the preview just looked blank which is what got me started with this in the first place.
                          • Re: Macro help
                            Fifi Riri
                            Just for info:
                            dxf can't have thumbnail because it's a simple text file (you can open it with notepad)
                            while dwg is a container that can contains data and metadata
