How to access negative coordinates in 2D workspace
Question asked by Roger Mertin on Dec 5, 2018
Latest reply on Dec 6, 2018 by Roger Mertin
Hello:
I have an object located from a copy-paste command in the region of the workspace below the origin of the PCB and cannot move the workspace down far enough to select and delete. If I switch to 3D mode I can navigate down to the object and see it, but cannot delete it in 3D mode.
I tried changing the origin to try and move the object into the positive workspace, but that did not work. The object is a circle that appears in the component and bottom layers.
I tried searching for it via the PCB command, but the circle isn't attached to any nets and doesn't come up when I search all layers for Arcs.
Any help would be appreciated.
Thank you
