I need to create a add-in for data card button.
I tried something, But its not working properly.
here are my codes
Imports EdmLib Public Class VbAddinSS Implements IEdmAddIn5 Private vault1 As IEdmVault5 = Nothing Public Sub GetAddInInfo(ByRef poInfo As EdmAddInInfo, poVault As IEdmVault5, poCmdMgr As IEdmCmdMgr5) Implements IEdmAddIn5.GetAddInInfo poInfo.mbsAddInName = "Test1" poInfo.mbsCompany = "Test" poInfo.mbsDescription = "For Testing" poInfo.mlAddInVersion = 1 poInfo.mlRequiredVersionMajor = 10 poInfo.mlRequiredVersionMinor = 0 'Get Card Button Click poCmdMgr.AddHook(EdmCmdType.EdmCmd_CardButton) End Sub Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As Array) Implements IEdmAddIn5.OnCmd If Left(poCmd.mbsComment, 9) = "MyButton:" Then MsgBox("Reached") End If End Sub End Class
When I click the button its prompt the following error.
Please fix this
Check this article (especially points 4 and 5): How To Create SOLIDWORKS PDM Professional Add-In
Most likely you are targeting to Framework 4.0 or newer and you are using wrong version of interop.
