Is there a way to get two digger ports in one view?
You can't get two interactive diggers in a Composer project. That's an ER documented in SPR 483692 - Ability to use multiple Digger tools simultaneously.
However, you can capture Digger content as a 2D panel and keep moving on. I use that trick a lot.
You can capture images with the digger, but you have no control over the quality. It is more like a screenshot
of your view/actual scene. With the method via the workshops Technical Illustration / High Resolution Image you can control
the resolution, DPI etc. And you can update your detail views very easy. So I would try the different tipps and see what fits best
for your workflow!
Best regards, Phil
No, this is not possible. But you can use multiple detail views (Workshop High Resolution Image (pixel-based), Workshop
Technical Illustration (vector-based))
If you need this for a video, render your "digger"-videos in another videofile and use something like
Adobe After Effects to layer one video on top of another.
Regards, Phil
