Macro to add reference point to selected faces, crashes? Please help.
Question asked by Derek Eldridge on Dec 3, 2018
Latest reply on Dec 6, 2018 by Derek Eldridge
I'm trying to learn more about the selection tool in the API as well as create a macro to add a ref point to the center of all 12 selected faces.
I get as far as addressing the selected faces, and then when I try to add the reference point, SW crashes.
Can someone tell me what I'm doing wrong?
I select the following faces:
Option Explicit
' 1 radian = 180º/p = 57.295779513º or approximately 57.3º
Const RadPerDeg As Double = 1# / 57.3
Const MaxUAngle As Double = 1# * RadPerDeg
Const MaxVAngle As Double = 1# * RadPerDeg
Dim swModel As SldWorks.modelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swBody As SldWorks.Body2
Dim swProcBody As SldWorks.Body2
Dim swNewPart As SldWorks.PartDoc
Dim swFeat As SldWorks.Feature
Dim vBodies As Variant
Dim errors As Long
Dim warnings As Long
Dim fileName As String
Dim status As Boolean
Dim swBodyVar As Variant
Dim swSelFaceVar As Variant
Dim swSelFaceCount As Long
Dim selectedFace As SldWorks.Component2
Dim selectedFaces() As Object
Dim selectionMgr As SldWorks.selectionMgr
Dim selObj As Object
Dim count As Long
Dim i As Long
Dim modelDoc2 As SldWorks.modelDoc2
Dim featMgr As SldWorks.FeatureManager
Dim NRefPointType As Integer
Dim NRefPointAlongCurveType As Integer
Dim DDistance_or_Percent As Double
Dim NumberOfRefPoints As Integer
Dim addpoint As Feature
Dim instance As swRefPointType_e
Set swModel = swApp.ActiveDoc
Set swPart = swModel
Set featMgr = swModel.FeatureManager
'Get and process body in part
vBodies = swPart.GetBodies2(swSolidBody, False)
Set swBody = vBodies(0)
Set swProcBody = swBody.GetProcessedBody2(MaxUAngle, MaxVAngle)
'Select multiple faces in new part
'Set swModel = swNewPart
Debug.Print "New part title: " & swModel.GetTitle
Debug.Print " Body faces: " & swBody.GetFaceCount
Debug.Print " Processed body faces: " & swProcBody.GetFaceCount
Set swModelDocExt = swModel.Extension
Set selectionMgr = swModel.SelectionManager
'Selects extra face
'status = swModelDocExt.SelectByID2("", "FACE", 0, 0, 0, True, 0, Nothing, 0)
Set selObj = selectionMgr.GetSelectedObject6(1, -1)
'deselects extra face
Set selObj = selectionMgr.GetSelectedObject6(2, -1)
count = selectionMgr.GetSelectedObjectCount2(0)
'Assign Selected faces to variables in array.
ReDim selectedFaces(count - 1)
For i = 0 To count - 1
Set selectedFace = selectionMgr.GetSelectedObjectsFace(i + 1, 0)
Set selectedFaces(i) = selectedFace
'attempt to Insert reference points on selected faces while addressing faces
addpoint = featMgr.InsertReferencePoint(swRefPointFaceCenter, 2, 0, count)
Next
'attempt to Insert reference points on selected faces in a separate for statment.
'For i = 0 To UBound(selectedFaces)
'Note: swRefPointFaceCenter = 4
'addpoint = featMgr.InsertReferencePoint(4, 2, 0, count)
'Next i
