Alice Caspari
Update the Configuration Properties "Description" to equal a Custom Property
Discussion created by Alice Caspari on Nov 30, 2018
In case someone has a use for this.....
' This code updates the Configuration Properties "Description" to equal that configurations Custom Property "ITEMMASTER"
Option Explicit
Dim Part As SldWorks.PartDoc
Dim Doc As SldWorks.ModelDoc2
Dim SelMgr As SldWorks.SelectionMgr
    Set Doc = swApp.ActiveDoc
    Set SelMgr = Doc.SelectionManager
    Dim params As Variant
    params = Doc.GetConfigurationNames
    Dim vName As Variant
    Dim Name As String
    Dim thisConfig As Configuration
    Dim cusPropMgr As SldWorks.CustomPropertyManager
    Dim lRetVal As String
    Dim FieldName As String
    Dim vPropNames As Variant
    Dim vPropTypes As Variant
    Dim vPropValues As Variant
    Dim ValOut As String
    Dim ResolvedValOut As String
    Dim wasResolved As Boolean
    Dim resolved As Variant
    For Each vName In params
        Name = vName
        Set thisConfig = Doc.GetConfigurationByName(Name)
        Set cusPropMgr = thisConfig.CustomPropertyManager
        '***Substitute the Custom Property name to be used instead of "ITEMMASTER" in the line below
        lRetVal = cusPropMgr.Get5("ITEMMASTER", False, ValOut, ResolvedValOut, wasResolved)
         thisConfig.Description = ValOut
    Next vName
