We are trying to implement SWE and are having a fundamental struggle that I hope someone can help with.
If I have a circuit, and I drop a connector on to the wires (dynamic connector hypothetically), I want one half of the connector to be labeled CF1 and the other half CM1. Essentially keeping the female and male halves of the connectors always numbered the same. The female connector 1, always goes with the male connector 1.
Is this feasible? IF so, can someone point me in the right direction on how to achieve this.
Shawn
One method would be to create a connector component, but not have any part numbers assigned to it. Name it C1, or C# whatever. Right click on the component, and click create connector. Manually name the first connector M. Right click on the C1 component again and click create connector and manually name the second connector F. Final result will be -C1-M and -C1-F. Whenever you want to use connector, if you copy and paste special those connectors (control+shift+v), and tell it to create a new connector, then it will result in this:
