0 Replies Latest reply on Nov 29, 2018 11:16 AM by Kyle Taylor
    Library feature pattern issue
    Kyle Taylor
      I have created a library feature of a bolted stair tread. I'm placing it on the face of the stringer, selecting a point, and selecting the opposite stringer to extend the tread out to. I have the bolt holes cut extruded out of the body, and I added a separate cut extrude feature at the same bolt hole location to cut the holes out of the stingers. This works perfectly until you pattern the feature to add the rest of the treads. All of the patterned bodies combine with the stringers to create 1 solid body in the cut list and the original tread is still it's own body. Is there something I can do to fix that? I dont have any features merging but it seems it is doing that anyways. I attached one of the treads and the test part to check out
