KTKevin Thompson28/11/2018
I'm trying to write a macro that will insert a comment into the feature tree and then rename the "Comments" folder followed by renaming the newly inserted comment in the feature tree.  I've been successful in writing code to insert the comment and rename the "Comments" folder, however, I've been unsuccessful in renaming the newly inserted comment in the feature tree.  I've got some decent vb experience in Excel macros, but virtually no experience with SolidWorks macros so i'm a bit lost on what to do next.  Any help would be appreciated!  The code that I've tried follows:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim feature As SldWorks.feature
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
Dim myComment As Object
Set myComment = Part.Extension.AddComment("TEST")
boolstatus = Part.Extension.SelectByID2("Comments", "COMMENTSFOLDER", 0, 0, 0, False, 0, Nothing, 0)
Set feature = Part.SelectionManager.GetSelectedObject6(1, 0)
feature.Name = "Comments Folder Name"
boolstatus = Part.Extension.SelectByID2("Comment1", "COMMENT", 0, 0, 0, False, 0, Nothing, 0)
feature.Name = "Comment Feature Name"
The comment gets inserted and the folder name gets updated to "Comments Folder Name" when i'm in break mode and run it with a break at the second 'feature.Name' command.  But when i run past the break and try to select the "Comment1" feature and change it's name, it changes the folder name again to what I want the comment feature name to be instead.  Any suggestions?
