MRMax Rodgers29/11/2018
I'm having trouble pulling the internal volume of this assembly. I have tried multiple approaches using Intersect, Cavity and Surfaces with no luck. I feel like the surfaces command would be my best bet but whenever I'm trying to offset the surfaces, it says that they are not touching (which is true). I previously was able to get internal volumes in Autodesk Inventor by using a surface offset and then patching the distance between surfaces. Is there a similar way to do this in Solidworks? Attached is an example assembly of the volume I am trying to find. The target assembly is Inlet Manifold Volume Test.
Thanks for any help!
