Re: Macro for importing inventor files and saving in .step
Niels Raahauge Nov 28, 2018 8:55 AM (in response to David Charron)'I think this code can help you ...
Dim swDoc As ModelDoc2
Dim fileerror As Long
Dim filewarning As Long
Const folder As String = "C:\Path_with_sw\"
Dim files As Variant
files = Dir(folder & "*.sldprt", vbNormal)
Do While files <> ""
swApp.OpenDoc6 folder & files, swDocPART, 0, "", fileerror, filewarning
files = Dir
Loop
David Charron Nov 28, 2018 10:08 AM (in response to Niels Raahauge)Thanks Neils, I will try to see how it can be use within my macro.
David Charron Nov 28, 2018 10:08 AM (in response to David Charron)Dim swApp As SldWorks.SldWorks
Dim sSearchPath As String
Dim sFileName As String
Dim objFolder As Folder
Dim fso As FileSystemObject
Dim objFile As File
Private Sub CButton1_Click()
'MsgBox ("macro started")
Dim error As Long
'SEARCH FOR THE FILES
sSearchPath = fMain.TextBox1.Text
Dim fso As New FileSystemObject
Dim bRet As Boolean
Set objFolder = fso.GetFolder(sSearchPath)
'MsgBox (objFolder.Name)
For Each objFile In objFolder.Files
'MsgBox (objFile.Path)
'open the file found - file type to be changed
If LCase(Right(objFile.Path, 3)) = "ipt" Or LCase(Right(objFile.Path, 3)) = "iam" Then
' MsgBox (objFile.Name)
bRet = swApp.LoadFile2(objFile.Path, "r") 'Load Inventor file
Set swModel = swApp.ActiveDoc
'save & close -
sFileName = Left(objFile.Name, InStrRev(objFile.Name, ".") - 1)
swModel.SaveAs (sFileName & ".step")
swApp.CloseDoc swModel.GetTitle
MsgBox (objFile.Name & "was converted")
Else
MsgBox ("not converted! Verify it is a part!")
Next objFile
MsgBox ("Done")
Private Sub UserForm_Click()
