Greetings.
I had the 2016 version and recently installed the solidworks version 20017/2018 and when I try to use the hold wizzard, it tells me that the drill database can not be found.
I already tried uninstalling the antivirus and even and uninstalled and reinstalled the solidworks and it still does not work.
When you upgraded versions, did you upgrade/update the toolbox?
Is the path correct to the data?
Are you using PDM?
If not Are the toolbox local or on a server?
Take a look at this:
How to manually update the SOLIDWORKS Toolbox - Innova Systems
