0 Replies Latest reply on Nov 26, 2018 5:21 PM by Andres Hernández
    How to flatten tip of pin
    Andres Hernández
      Hi, I would like to flatten the curved tip of the attached pin (about 20mm from the tip) like if the material was hammered or pressed in order to make it flat. It would look similar to the picture below. I also would like to keep the curvature on that end of the pin. I do no wish to model the part as flat in that area since I would like to replicate the manufacturing process in order to get the correct dimensions using that pin diameter. Any suggestions would be appreciated, thank you!
