I'm trying to run a motion analysis to simulate a spacecraft rotating without being in space. It's a very basic model and I'm just using it to show a physical description and the motion that is intended. I'm trying to have the model rotate the base, the linkages to move a piston up and down, and a sphere connected to everything before in both directions. Here's a picture of all the movements,hopefully they make sense. I've attached the pack and go zip file. Whenever I run the motion the pod and the arm rotates fine, but the base and the piston causes issues. Any help would be appreciated. I get this error when Iunsupress all the motors
Number of new element states 2 doesn't match number of old ones, 3. |
If this is what you're talking about, I didn't see a nuisance.
see attached video.
Can you add a video?
