I have an imported STEP file which has been converted to a weldment part in SolidWorks. Some of the parts are bent.
How do I convert these bent parts to sheet metal so I can flatten?
Mark (SolidWorks 2019 sp0)
RMB on each cutlist item
run "Insert Into New Part" command
in derived part, run "convert to sheet metal" command
that`s all
Hi Igor,
Another question on this, how can I get the flattened length in to the cut list, Do I have to manually add it. At the moment the cut list shows the bounding box size which is a lot shorter than the flat pattern size.
Mark
What is the name of your property?
It must be "Bounding Box Length" (not 3D-Bounding Box Length of bounding Box feature).
No way, but you have to look at "Bounding Box Length" instead, it contains the length of flat pattern as you wish (not length of the bended part).
that`s all
