Good morning and greetings from Germany,
To begin with, i´m using Solidworks 2018 SP4.0
Now my little question.
For some reason, everytime i create a folded metal sheet and add it into an assembly,
the values for correction factor, inside bending radius and sheet thickness are shown as floating measurements.
The more parts i add, the more it slows my program down. I don´t know how i deactivate these measurements.
Sometimes i can click on them and most of them vanish once i start rotating the assembly. But once i stop rotating, they reappear.
Here is a little example
Does someone know how to deactivate these measurements?
Thank you in advance
Hi Johann,
Do the dimensions show when you view the part as a part only?
Do you use a specific template for your sheetmetal parts?
Right click on "Annotations" in the feature tree and have a look at what dimensions you have selected to be shown. Do this for both your part and assembly templates. I'm pretty sure you'll find the culprit.
Dave.
