Hi Gaurav,
The Warp analysis uses residual stress data results from Flow & Pack. Those results are missing !
This might explain the error message you have. I suggest you run only the Flow and Pack and make sure your settings are OK and everything run smoothly. Then, you could attempt to perform the warp.
Also, you need Plastics premium to run Warp analysis.
Hope this helps
Mohamed
