Hi, I have been having trouble lately performing text extrusions in Solidworks. Specifically with regards to the letter N. Our company requires use of a specific font, called ethnocentric, which I have attached to this post.
The problem I run into is that sometimes Solidworks will not extrude the letter N. It works sometimes, but other times I have to use the dissolve sketch command, which is a terrible workaround for my purposes. Usually this occurs on a part by part basis, however I just ran into an example where one part has both results. I have included the aforementioned part to this post as well.
Does anyone have any ideas on how to fix this, or a workaround that does not involve turning each letter into thousands of little line segments??
Matt
